Re: beko door seal
front comes off, open filter door, 2 screws and plinth moves right then out.
3 screws at bottom of front panel hold it on, undo door lock and seal and push panel down it is clipped on and both sides.
you need to remove concrete block 5 torq bolts hold it on it is a pig to get off even with bolts removed might be best to remove facia panel 1st but you cna squeeze it past.
once weight is removed remove the hose at top and spring clamp round seal, refit new seal and rebuild in reverse,
good luck you’ll need it 😉
