This one has me stumped.
Main oven stopped working after electrics tripped.
Sounded like a straightforward element thing, but no.
Indicator light not coming on, no fan, no heat, nothing. Everything else apart from the main oven works, including clock, grill/oven, hobs etc.
Checked everything. All seemed in order, continuity and insulation wise. The only thing I wasn’t sure about was the fan, it’s marked 21W, but resistance was c.190 Ohms, so replaced with new 21W fan (resistance is c.275 Ohms).
Started checking the wires continuity, there’s a couple of ohms there. Customer flipped switch off and on at the consumer unit.
Put everything back together and tried again, the indicator light for the main oven now comes on when it didn’t before, but still no heat or fan running.
Would appreciate any pointers of what could be going on here.
