BEKO DPH8756 – No Fault Codes
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum BEKO DPH8756 – No Fault Codes
  • #102389
    Doug99
    Hi All
    My machine is not completing a full cycle but no fault codes are displayed.
    Is there a key stroke sequence for front buttons to bring up a test programme or fault register?
    Cheers
    Doug
    #488616
    andyjawa
    No idea if there is a test programme.
    What these things do do is on the heater there are two stats. One with a rest button and the other stat is really a thermistor (but does not look like your normal torpedo styled one. It was pretty common, from memory, that that thermistor stat went to varying degrees to earth which caused the problem you have without taking out the house trip (if you have one). You might want to whip the back plate off the machine (noting the differing screw positions) and test the themistor ideally with a megga. If this is the culprit you cange the heater as one unit. Sure that you cannot buy the thermister by itself! You want to check this first before thinking gambling on a going down the pcboard route.
    #488617
    andyjawa
    One with a rest button. correction: reset button
