Beko DPU 8360 W tumble dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DPU 8360 W tumble dryer
  • #83840
    Alanj
    Hi guys, anyone come across one of these before. It’s a dryer with a heat pump. This one was running for a few mins then stopping with empty water light on display. Checked water chamber and pump and they’re ok. After cleaning condenser filters, I tried it again. It is running on ok now but doesn’t seem to produce much heat. Any info would be much appreciated. First one I’ve seen.
    Alan
    #423943
    Chris Blatch
    Re: Beko DPU 8360 W tumble dryer
    Hi Mate,
    Basically, the heat pump is a fridge system, the condenser will produce the heat and the evaporator will remove the moisture from the air flowing over it.
    If you put it in to diagnostic mode, it will run a self check on the heat pump system and let you know whether it is functioning or not. If the heat pump system is faulty, such as lost any gas or weak compressor, it will be a write off unless under warrantee.
    Remember these do run cooler than a standard TD (approx. 30{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}), it’s all about the temperature differential, so drum temp may be around 60 degrees C.
    #423944
    Alanj
    Hi Chris, do you have the procedure to put it into diagnostic mode?
    Alan
    #423945
    alro
    hi alan
    has it got an error code showing on display
    cheers alro
    #423946
    Chris Blatch
    Could you send me the full model number and S/N and I’ll pass it on
    #423947
    Alanj
    Hi alro, no error code.
    #423948
    Alanj
    Chris only took photo of label on rear of machine with barcode on it. It’s a DPU 8360 W bar code
    5 023790 026314 if that helps.
    Alan
    #423949
    Chris Blatch
    PM’d you Alan
