Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Beko DPU8360w Heat Pump Dryer Error Codes 5 & 20?
- This topic has 6 replies, 2 voices, and was last updated 10 years, 3 months ago by
ldt.
December 16, 2015 at 10:57 pm #87062
ldt
ParticipantWe’ve had this dryer for just over two years and it has just stopped drying. Drum still rotates and it appears to be operating as normal but with the exception of actually extracting any moisture from the load or even getting warmer inside. I’ve not been able to find a service manual but have managed to trigger a service mode by turning the selector to ‘wool refresh’, holding down the ‘buzzer cancel’ and switching on. Without a manual its pure guesswork but as I cycle through using the start button I get:
Test
65hp
Er 05
Er 20
Bzzr…buzzer sounds
20
Ntrl…drum spins
Fan..fan works
Pump…pump runs
Ntrr…drum spins
Hund….drum still spinning and no more options come up, have to turn off main switch to stopI’m guessing the two error codes contain the info I need to see if this is likely to be a cost effective fix or a new machine. Can anybody assist?
December 16, 2015 at 11:37 pm #433861electrofix
ModeratorRe: Beko DPU8360w Heat Pump Dryer Error Codes 5 & 20?
both dont hel you
er5 if start pause is pressed during run mode
er20 if rotary is turned during run mode
both thing kids could do to the machine
dave
December 17, 2015 at 12:11 pm #433862ldt
ParticipantRe: Beko DPU8360w Heat Pump Dryer Error Codes 5 & 20?
Many thanks for the fast response Dave.
Both of those events are eminently possible with a 2 year old in the house!
Should the compressor run during one of those stages, are there any known common failures on these machines?
Cheers
December 17, 2015 at 9:23 pm #433863ldt
This evening its popped up with codes 1 and 15, are these of any use?
December 19, 2015 at 8:24 pm #433864electrofix
posted in error
December 19, 2015 at 8:25 pm #433865electrofix
error 1 door open
error 15 drum idle ( only at beginning of sensor dry progs )
December 24, 2015 at 6:41 pm #433866ldt
Thanks Dave,
Had an engineer out today and it turned out to be a seized compressor, deemed uneconomical to repair.
