Beko DRCS68 changing the cylinder fan
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko DRCS68 changing the cylinder fan
  • #85315
    skeggylad
    Hi is there a giude to removing the Motor so i can replace or clean the Fan its making some noise so dont know if its off balance due to dried hardened fabric or if its loose
    thanks
    #428334
    Seamy
    Re: Beko DRCS68 changing the cylinder fan
    Get an engineer to do it as it is not easy!
    Set aside a few hours and have some choice language set aside as you will most likely refer to them later.
    Power off, plug out! remove top panel, remove about 50 screws attaching rear panel,side panels will come off for better access, remove cable to heater and cable from power in, take out drum completely, tear out your hair, say WTF did I ever start this,
    remove condenser covers, remove motor & fan, remove said item that is blocking fan , or replace damaged parts, now try to reassembly, pull out hair some more & wonder WTF did’nt I just get an Engineer to do it. 😉
    #428335
    skeggylad
    Ok il just put up with it then buy another lol
    cheers saved me some skinless hands and a few coppers in the swear jar
