beko drcs68w Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko drcs68w This topic has 4 replies, 4 voices, and was last updated 16 years, 2 months ago by robbo1973. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts January 27, 2010 at 6:55 pm #52026 robbo1973Participant this guy is complaining of no heat on the sensor cycle but if he puts it onto the timed cycle it runs ok.are there any issues on these as i have never seen one before.any info appreciated. cheers chris January 27, 2010 at 8:20 pm #310361 GalwayParticipant Re: beko drcs68w try running the test program from page 7 on known error codes and if everything works then its got to be the control board January 27, 2010 at 9:27 pm #310362 helo_75Participant unless its in a cold room we’ve discussed this a lot recently.. if its under 5 degrees, the ntc is way out of tolerance January 27, 2010 at 9:45 pm #310363 robbo1973Participant Re: beko drcs68w thanks very much for replies ,it is in a warm kitchen and i will try the test programme January 28, 2010 at 8:07 am #310364 funkyboogyParticipant Re: beko drcs68w could aslso be dust trapped behind sensor…remove and clean should be inside front lip of drum at bottom,, ally Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
