Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko DRCS68w Condenser Drier only 1/2 element heating.
- This topic has 9 replies, 4 voices, and was last updated 14 years, 10 months ago by
TELL.
May 24, 2011 at 7:08 pm #62986
TELL
Participantwent to this drier today and found only 1/2 the element heating. checked element with meter, and getting continuity on all of the element filaments?. But could not disconnect fully from connector block,might be getting reading off anoyher circuit, the output on the element+ the motor is 1.6Kw, and the m/c is rated upto 2.2Kw, therefore loosing .4Kw.
the thing is I’m wondering is the control PCB only giving 1/2 heat, or is it the element itself.
any info apprieciated, ie wiring diagram, or expierence of this problem.
thanks.
TELL..May 24, 2011 at 7:51 pm #352095Jazzmeister
ParticipantRe: beko DRCS68w Condenser Drier only 1/2 element heating.
Usually the stat located in the front of the appliance!!
hope this helps!Jazz!
May 24, 2011 at 10:42 pm #352096TELL
checked that jazz, i have contiuity through the stat, and i think that one in the top at front is for the sensor, on autodry?.
TELL..May 25, 2011 at 8:02 am #352097Seamy
How were you testing it? It will only heat on 1/2 heat on timed drying, on sensor drying full element should come on after a few seconds. In service mode you can run it on full heat or half also to test.
May 25, 2011 at 10:24 am #352098TELL
thanks for that info, will give another go.
TELL..May 25, 2011 at 10:31 am #352099TELL
PS. whats procedure for service mode,
TELL..May 25, 2011 at 8:01 pm #352100TELL
Got that info through on my email Seamey,
thanks for your help, I dont feel like an idiot now, espiecialy when you have the info required.
TELL..February 13, 2014 at 7:54 am #352101suedehead1
hi i have the same problem with 1/2 heat on the dryer was going to try a new heater.
February 17, 2014 at 10:57 am #352102TELL
Hi Suedehead,
Been a long time since I was at that one, looked back, found to be simply the condenser all blocked up, not allowing the proper air flow throught the drier.
check it out 1st, before you buy the element.
Tell..February 17, 2014 at 8:59 pm #352103suedehead1
Thanks I will take another look
