Beko DRCS68W condenser dry belt + modif info going on Monday
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DRCS68W condenser dry belt + modif info going on Monday
  • #66445
    Rograbbit
    Hi guys. Checked the forum on this and apparently some of these have got a modification to stop the belt breaking again. This one is only 15 months old so may have an issue. Can anyone e-mail some info on this? Bob hope helped the last time. Not fitted one of these yet. 🙁
    #364195
    preggy
    Re: Beko DRCS68W condenser dry belt + modif info going on Mo
    Generally its the front felt bearing which causes this.
    They split & jam the drum, which then makes the belt skid & snap.
    Change front felt & belt every time.
    Be very careful the belt is a b*st!rd to fit!!!
    #364196
    Rograbbit
    Thanks Preggy. Better allow a bit of time. I presume it’s a tight stretch belt with no jockeys?
    #364197
    BobHope
    Rograbbit pm me an email address and i will send you some info.
    Bob.
    #364198
    Seamy
    Beko recommend you change the bearing housing assembly also, new front felts on bearing housings are stitched together & dont fall apart. Clean off the front of the drum of any sticky plastic residue as its this that normally causes the re-occurrance of belts breaking, if its not cleaned it will stick to new felt & take it off .
    #364199
    Rograbbit
    Thank you seamy. All good advice.
    Bobhope I have pm you my e-mail address. The more info the better. Thank you guys for your trouble.
    #364200
    Rograbbit
    Thanks Bob that info is great. 😀
