Re: Beko drcs68w condenser dryer water tank full
Come across it a few times, a multimeter comes in really handy 😉 , check connector to float switch, if its low snip it off & use 2 insulated spade connectors instead.
Of course the clean filter & empty tank will come on every time a programme finishes whether its finished or has encountered a problem, they are indicators for the customer to clean filter & empty tank, even if tank is not full it will come on at end.
