Beko condenser TD not heating only half heat.Fitted new element as old one was shot and sagging.Not heating on full ,condenser is clean have 240v at element .Cleaned all fluff from behind sensor bar and checked stat above door reading was 25k ohms is this correct as this measures same as stat on new element ?Thinking pcb fault as dryer works apart from no full heat on sensor drying with damp towels in.
Just like to update ,problem solved .Heater relay stuck open Replaced relay and all working fine.A tip for a quick check for stuck relay not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} but Smack the relay housing with back of screwdriver and see if the contacts come unstuck while still attached to board first to see if it works. I tested my relay out of board with dvom and tried energizing the faulty one to clarify it was faulty . Mine came unstuck when smacked .New relay then soldered in and all working . .If it don’t come unstuck while in board you can just solder in a new relay after testing old one out of board if you like . Here is board with heater relays circled .Only one relay stuck .
