Beko DRCS68W – Noisy in reverse only
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DRCS68W – Noisy in reverse only
  • #88557
    Hollytree_Technical
    Hi All
    This machine is beginning to annoy me:
    The problem is that whenever the machine runs in reverse it sounds very noisy as if it is binding but is very quite in the forwards direction.
    I have done all of the following:
    Replaced all 3 slide pads
    Replaced the motor start capacitor
    I have also checked that the fan is not loose
    There is no play or wear in the rear bearing or motor shaft
    The front and rear seals are fine
    I have polished the front edge of the drum
    I cannot feel the problem when turning the drum by hand.
    I am not sure what else it could be – any ideas (other than skip).
    Jem
    #438556
    Seamy
    Re: Beko DRCS68W – Noisy in reverse only
    Take belt off & look for motor judder, see if its actually drum causing noise or motor,
    may be faulty motor, check mounts, tensioner etc
