The above dryer heater was replaced with a non genuine Qualtex part due to an open circuit toc.
The replacement heater came with a manual reset toc which is now tripping after a week or so of use. Condenser is nice and clean and cap seems ok.
Are there any other issues I could check on this dryer ?
Just that heater has an NTC & not a thermostat. Some early Beko dryers had similar looking type heater wich had a conventional switch on & off ‘stat. This model requires a heater with an NTC, new type will have a resettable cut-out in place of original one-shot type.
Genuine part number should be 2957500800
I’d be checking air path then for blockages etc, make sure fan is not loose on shaft or blocked up. Make sure back cover is on tight & that no air is escaping, also make sure that air intake is clear as these can get blocked up with fluff, dog hair etc.
