BEKO DRCS68W, rotates once and stops intermittently
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum BEKO DRCS68W, rotates once and stops intermittently
Viewing 1 post (of 1 total)
  • #72444
    fordmondeo1
    Hi, The dryer will run OK and the next tiem you use it, it will start and rotate once and stop! The lights all look fine, if it is switched off and on it might then run OK or again it might rotate once! Help please..
