Beko DRCS76 Still Damp at End of Cycle
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko DRCS76 Still Damp at End of Cycle
  • #91249
    jimmylad007
    Hi all.
    I’m hoping I can get some advice regarding my Beko DRCS76 condenser sensor dryer. Clothes have started coming out still damp at the end of the cycle. Not soaking wet, but certainly far from dry. I have to let the machine and the load cool down before running it again half an hour later. They usually come out OK the second time round.
    Steps I have taken so far are:
    Soaked and jetted out the condenser. Both the hot drum air channels and cold room air channels are perfectly clear.
    Scrubbed the two sensor bars inside the drum with vinegar.
    Cleaned the removable filter mesh and two fixed filters, also with vinegar.
    Thanks in advance for any help.
    #447549
    jimmylad007
    Re: Beko DRCS76 Still Damp at End of Cycle
    Plus I’ve also hoovered the room air inlet/outlet vents at the front by the condenser.
    #447550
    kaibart
    I now this might sound silly but have you changed the cycle you use on your washer? A extra spin on your washer will help. Kai
    #447551
    jimmylad007
    kaibart wrote:I now this might sound silly but have you changed the cycle you use on your washer? A extra spin on your washer will help. Kai
    Nope. Same cycle as I’ve always used, with max spin. No issues with overloading either.
