Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › BEKO DRCS76B 7KG CONDENSER
- This topic has 9 replies, 6 voices, and was last updated 14 years, 6 months ago by
funkyboogy.
September 16, 2011 at 11:07 am #65089
funkyboogy
ParticipantDRCS76B 7KG CONDENSER
Serial Number 1020170602
STARTING TO SNAP BELTS – HAD 2 IN LAST 4 WEEKS – DRUM SEEM FINE IE FREE NOT STIFF ETC
was there a drum change on these ..
cheers allySeptember 16, 2011 at 4:20 pm #359097washtronics
ParticipantRe: BEKO DRCS76B 7KG CONDENSER
i have had a few of these and also the vented type snapping belts. Remove the drum and check front seal, the ones i have repaired were getting jammed somewhere on the front seal. The vented type i gave up on as it snapped 3 belts in a week, i removed drum twice and found no reason for it-just lost money on that one and it has put me off repairing them.
September 16, 2011 at 5:23 pm #359098BobHope
there is a technical mod out for this problem but its not a cheap fix, pm your email address and i will send som info.
Bob.
September 17, 2011 at 7:26 am #359099johnnyj
Hi Bob can you send me the tech info, i had one snapping belts, i removed the drum the last time and replaced the bearing pads as they looked like the drum might have been jamming on the duct on a large load, i’d like to be sure i know what is causing it cheersJJ
September 17, 2011 at 7:44 am #359100BobHope
pm me your email address johnnyj, and i will send you some info.
Bb.
September 17, 2011 at 12:57 pm #359101shaun67
Hi Bob,
Any chance you could email me some tech info please as well .Had one snapped about 3 weeks ago but been ok since (fingers crossed)would like to know in-case it does go again.
Cheers
Shaun
September 23, 2011 at 4:29 pm #359102washtronics
according to the technical info if the belt snaps then the drum and front felt bearing have to be changed as well? might as well scrap it-if i told a customer i would have to change these parts as well they would think i was trying to scam them!
September 23, 2011 at 9:18 pm #359103shaun67
washtronics wrote:according to the technical info if the belt snaps then the drum and front felt bearing have to be changed as well? might as well scrap it-if i told a customer i would have to change these parts as well they would think i was trying to scam them!
Thanks for that info washtronics, as nobody else replied 😥
But at least i know now though 😉
Shaun
September 24, 2011 at 9:46 am #359104Seamy
Normally if the felt has gone it leaves a nasty sticky residue on the front of drum, also if it has cut through the bearing slides theres plastic burn’t onto drum lip. If this is not removed or cleaned off the drum, it will catch on new felt & break belts again. New appliances now have a sewn joint in the felt & a more rounded front edge on drum, the belt has a tensioner on motor to prevent snapping belts.
September 24, 2011 at 4:36 pm #359105shaun67
Seamy wrote:Normally if the felt has gone it leaves a nasty sticky residue on the front of drum, also if it has cut through the bearing slides theres plastic burn’t onto drum lip. If this is not removed or cleaned off the drum, it will catch on new felt & break belts again. New appliances now have a sewn joint in the felt & a more rounded front edge on drum, the belt has a tensioner on motor to prevent snapping belts.
Thanks for that info as well Seamy 😀 Hopefully the belt i fitted has done the job (well at least for now it has :wink:)
shaun
