Beko DRCS76W
  • #63094
    DDDave
    A previous engineer has removed one of the pair of stats from the element of this machine. Can anyone tell me what value these stats are please.
    Thank you.
    #352513
    geoff1
    Re: Beko DRCS76W
    Do you mean the ones attached to the heater as theres are only available as part of the heater assy. From memory later heater will have a one shot cut out and a resetable cutout. the early version where both one shot.
    heater part number is 2957500800 for both versions
    Geoff
    #352514
    DDDave
    Re: Beko DRCS76W
    Thanks Geoff. Thats them. I fitted another stat in place of the missing one for testing but still have no heat on timed or sensor dry. Does this mean the prog board is gone too ??
    #352515
    geoff1
    Re: Beko DRCS76W
    Would check circuit through both cutouts and heater. Neutral is direct back to mains input.
    Ensure tht you have 240v to heater on timed dry. If not check that yo have output from module plug KN2 (600w) and KN7 (1400w)
    Both outputs are controlled by relays on board
    HTH
    Geoff
    #352516
    Seamy
    Re: Beko DRCS76W
    Heater assembly has a Cut-Out & an NTC on it!
    #352517
    DDDave
    Re: Beko DRCS76W
    Seamy wrote:Heater assembly has a Cut-Out & an NTC on it!
    What value would the NTC be Seamy ??
    #352518
    Seamy
    Re: Beko DRCS76W
    NTC is part of heater assembly as is the cut-out, they are rivetted on & should’nt be replaced on their own.
    Beko parts are dirt cheap anyway, heater is less than £30.
    Part number 2957500800
    #352519
    DDDave
    Re: Beko DRCS76W
    I want to check if thats all thats wrong with it before I get a new heater assy. It also needs a belt and the customer doesnt want to spend much on it as its only a Beko.
    #352520
    geoff1
    Re: Beko DRCS76W
    You will need to check the front felt/front bearing unit for damage as Beko are having a problem or two with the belt breaking because of this.
    up to serial number 10…….09 part number is 2966000300
    from serial number 10…….10 part number is 2966001100
    Has the customer complained of black marks on clothes as this will also be a sign of the front bearing/felt being gone.
    It would be worth checking before you get a new belt/ heater
    Geoff
