Re: Beko DRCS76W element not heating
3 points I can think of
1 unless you select a timed programme some dryer wont heat and some wont heat on the timed prog either. machine will be looking for dampness (energy saving )
2 you say only 2 element were working. I assume from that you tried it with the back off. you cant rely on that test as the elements only glow due to lack of airflow and the top elements will glow hotter
3 its the relays on the board that switch the elements on and they can fail
