Hi We have a Beko DRCT 70W it runs for about 10 mins heats etc ok then it beeps and the clean filter and water tank full lights come on.Filter and tank both ok.
Thanks in advance
Is it running with a small load by any chance? If you look inside drum under door aperture you will notice 2 sensor bars, if no damp clothing come in contact with these bars on sensor setting it will shut off.
Check condenser for blockages also.
