Re: Beko DRCT70W Condenser Tumble Dryer Problem
This is not a fault, every time a sensor program finishs it throws on the clean filter & empty water tank lights as a reminder to the customer to do this. Did you test the appliance with damp clothing, if there’s no damp clothing in it, it shuts off after 10 min’s or so, you can test it in timed drying & it shouldn’t go off till time has elapsed. Things to check are that the condenser is not blocked,if it is or was there can be excess moisture produced, this can cause the heater to get quite damp as there is poor air flow through it, shorting the NTC , causing funny readings, if down to earth it will sometimes trip electrics in house.
