Beko drive belt
  • #91109
    Model No: WMI 71641
    Part number for belt or alternative required please.
    TIA. Jim.
    #447085
    Re: Beko drive belt
    I had looked in the store but couldn’t see the correct model number but obviously didn’t look closely enough. :innocent:
    Will hang fire until you let me know if you have sourced the AW23 drum pulley. 🙂
    #447087
    Re: Beko drive belt
    Heads up on this one, I would advise anyone ordering this belt to get the genuine one.
    I have just been to fit the pattern belt that UKWG’s have sourced from Electrue.
    The new belt is a BLT9445 and has the size on the belt of 1265PJ. This is the same size on the original belt but this pattern one is far too big. It is slack to fit and has around 2 inches of movement between pulleys, totally useless. 🙁
    #447088
    Re: Beko drive belt
    That’s a bit bizarre!
    Re: Beko drive belt
    That is not quite what I said at the time. 😉
    #447090
    Re: Beko drive belt
    I’m sure, well weird though to be that far out.
