Beko drum bearings
  • #99432
    Shmoe90
    Hi, I’ve got a Beko WM84125W which has developed noisy drum bearings. I’m struggling to find replacement bearings, which I’ve now found out is because it’s a welded drum . I don’t suppose anyone knows what size bearings I need? Because I’ll be damned if I’m splashing out for a new machine for the sake of a couple of bearings. Any help would be much appreciated.
    Cheers,
    Joe
    #476413
    The bearings won’t be a problem, the seal may be and there’s no way to know what’s in it, there is no info at all on any internal parts.
    andyjawa
    Here`s a tip. Bearings or no bearings it matter not since you would have to cut the sealed tank in half to remove the drum to change the bearings and oil seal then use some sort of glue or perhaps seaweed and snot and self tappers to bodge the whole plot back together and then phone up your house insurance company to tell them about the resulting flooding disaster… you have not thought it through have you? It is a new sealed tank or a new machine. A sealed tank is a sealed tank. Bad luck.
