Home › Forums › General Trade Forum › beko drum paddles / welded tubs ?
- This topic has 16 replies, 9 voices, and was last updated 15 years, 3 months ago by
funkyboogy.
December 17, 2010 at 6:05 pm #59656
funkyboogy
Participantanyone seen these yet ?
seemingly you cant get paddles – its a whole tub job ..
we have received a tub assy – had a look at paddles through sump hole and true enough they are bolted from inside ..
bit of a mare .. this cant be eco friendly – whole tub if 1 paddle falls off ..
ally
December 17, 2010 at 11:38 pm #339065iadom
ModeratorRe: beko drum paddles / welded tubs ?
It has been mentioned a few times in the past. 😥
Its only as stupid as the Beko WMA machines, ISE included. The drum support is bolted to the inner drum with easily removable, sturdy bolts yet you can only get a complete drum and support assembly. A really criminal waste of a perfectly good inner drum in most cases. :rolls:
December 19, 2010 at 10:21 am #339066philfish
ParticipantRe: beko drum paddles / welded tubs ?
I did contemplate using a hole cutter on the top of the drum above the bolt to gain access and then sealing it back up with something like the old blanking grommits/blanking plates they used to use on the old zanussi to fill in the un used thermostat hole.
It is only a thought though it just seems like such a waste to scrap a machine because of something so trivial.Phil.
December 21, 2010 at 11:03 am #339067loopey
ParticipantDecember 21, 2010 at 12:39 pm #339068Martin
loopey wrote:its BER
No, no Loopey…..you need to fit C00113038 Drum Shaft Kit then the job’s a good ‘un.:wink:
Mind you, to be fair, there is a tenuous link between the 2 manufacturers. In the blue corner: Indesh*t and in the red: Beko (Arcelik) both have a certain whiff about them. 😈
December 21, 2010 at 1:47 pm #339069loopey
Thanks martin but how do you get the old shaft off ,its in between the 2 skins of the tub ?? . no scews no nothing its punched together . or am i being blonde ?:)
The C00113038 you gave me is the standard kit fitted thousands of them
December 21, 2010 at 2:06 pm #339070Martin
Saw the shaft off then screw the shaft kit on top!
December 21, 2010 at 2:40 pm #339071helo_75
Participantfor once martins right… grind it flush if u have to
they want u to think its b.e.r
but thats what i do anyway
December 21, 2010 at 3:20 pm #339072loopey
yo helo . thanks guys will give it a whirl 🙂
December 21, 2010 at 3:24 pm #339073Martin
Participanthelo_75 wrote:for once martins right…
I’m starting to like this helo guy. 😀
January 12, 2011 at 10:29 pm #339074Sparkcymru
Beko WMA spider and drum are available from connect as individuals for some machines. I’ve done the spider on my own WMA765S. Like you say its bolted nicely to the drum and a fairly easy job, but I didn’t have to buy the drum. Same on the WMA745. Other WMA machines seem to have complete drum only available. Weird!
Steve
January 13, 2011 at 5:43 pm #339075Madmac
ParticipantMartin wrote:
helo_75 wrote:
for once martins right…I’m starting to like this helo guy. 😀
Got to take all the praise you can get Martin 😉
June 14, 2011 at 4:59 pm #339076twicknix
I too found out the hard way today with Indesit IS60V. I usually come across with bolted shaft but this was the first.
So looks like I am having to keep an angle grinder in the van along with grinding disc as well a drill with a good set of drill bits. May as well have a mobile forge at this rate!! Not a good way of doing it from health and safety views.
to make matters worse, the client failed to mention the burning smell after I noticed the burnt fluff being stuck on to the elements, so the heater had to be replaced not by the next guy next week from the insurance, also once I have put it all back together the sodding motor failed so how was I supposed to know that as the belt snapped shortly after the drum bearings failed – I assumed that the motor was fine. And I do not work for the insurance as I am an independent.
Am I supposed to test every components before going down the route of replacing drum shaft? All that for the client’s insurance work at a capped price. Never again!! I learnt my lesson! Very pi££ed off. But I didn’t know that I was doing all this for the insurance until the client informed me that she is making a claim later today. If she had told me this earlier, I would have sold her a new dryer at a fraction of the price of repairing! If I had the foresight, I would have said BER and sell her a new dryer just to save the hassle.
June 14, 2011 at 6:08 pm #339077Martin
twicknix wrote:All that for insurance work at a capped price. Never again!!
One day very soon all machines will have welded tubs. Too costly for insurance companies to contemplate replacing so angle grinders and lump hammers will no longer be a necessity…never fear.
June 14, 2011 at 8:34 pm #339078twicknix
Martin wrote:
twicknix wrote:
All that for insurance work at a capped price. Never again!!One day very soon all machines will have welded tubs. Too costly for insurance companies to contemplate replacing so angle grinders and lump hammers will no longer be a necessity…never fear.
I’ll reserve my judgment on that… Just to make it clear, I do not work for the insurance company just that a customer of mine was using the insurance and employed me privately that she will be reimbursed for the work I did. I thought that insurance prefered their own people rather than the local guy.
Angle grinder and lump hammer are the way forward… might get a mig welding as well! 8)
