beko DRVS 62W noisy drum
  • #66604
    slyp98
    i had this today , very loud when running and sometimes wont turn at all , the drum has a lot of play at the front and a little at the back the plastic bush is a bit worn anyone come across this , is there a bearing kit available thx
    #364637
    tash
    Re: beko DRVS 62W noisy drum
    hi, its common for the front seal to get worn and twisted jamming drum etc, ived just changed the seal its self but think beko have advised changing whole front plate inc seal…tash
    #364638
    slyp98
    cheers tash is the front seal thick it seems this one could be missing 10-15 mm of play up and down also are there plastic pads like the creda hotpoint front parts ?
    #364639
    tash
    as far as i remember its just a felt type bearing that goes full circle,.part 2961080100…tash
    #364640
    slyp98
    on further inspection of this it turns out the motor is also making noise , loose bearing on the shaft, belt end customer scrapping m/c
