BEKO DRVS 73 W HEATING ELEMENTS CUT OUT
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum BEKO DRVS 73 W HEATING ELEMENTS CUT OUT
  • #73206
    zenithtime
    The dryer will run anti clockwise for say 20 seconds and both elements come on. there is a click and the dryer then goes clockwise and the elements remain off for every cycle
    Zen
    #386752
    zenithtime
    Re: BEKO DRVS 73 W HEATING ELEMENTS CUT OUT
    sorted, sensor fault just inside door
    #386753
    Seamy
    zenithtime wrote: the elements remain off for every cycle
    Zen
    Sensor bar fault should’nt effect all programs, only the sensor dry ones, it should work on timed drying o.k even with a faulty sensor bar.
    #386754
    zenithtime
    thanks for getting back to me, it is still playing up, i have changes the elements , cleaned about everything i can, still not getting hot help !!!!!!!!!!
    #386755
    Seamy
    Theres a low temperature switch on the front, make sure its not selected, e/g lit, if it was selected dryer runs only on 1/2 heat.
    N.T.C controls heating during drying with sensor under door switching off when degree of dryness is achieved.
    Problems with poor heating could be attributed to blocked fan, blocked ducting or filters, or even on the outlet grill on outside of wall where vented air exhausts.
    P.C.B could be at fault but this should be last resort to change.
    #386756
    zenithtime
    Hi Seamy
    the model doesn’t have a low temp button, all the venting seems free, i have cleaned the sensor just inside the drum and the one just inside the fascia
    thanks
    zen
