Beko DRVS62S
  • #62488
    franz
    This t/d wont start just beeps twice when star button is pushed. Thinking PCB unless anyone knows better.
    Thanks Franz
    #350256
    cab
    Re: Beko DRVS62S
    check the lever that holds the condensor in, the top right activates a microswitch, the machine wont work if the lever isnt up, have had one where the microswitch actuator was bent,
    #350257
    cab
    Re: Beko DRVS62S
    WRONG MODEL, yours is the vented one, is the drum siezed?
    #350258
    franz
    Re: Beko DRVS62S
    no, drum turns freely
    #350259
    cab
    Re: Beko DRVS62S
    diagnostic
    cancel prog and switch off
    select delicates
    while pressing BUZZER CANCEL switch back on keeping BUZZER CANCEL pressed for 3 secs
    release button the leds should flash
    each time the start button is pushed will run thru the test prog
    if either the CLEAN FILTER or TANK FULL led flash the heaters arnt activated
    if CLEAN FILTER led flashes ntc faulty
    step 1 in test start led blinks
    2 all leds blink
    3 motor rotates a-c’wise
    4 motor a-c’wise and heater on 1400w
    5 motor a-c’wise and heater 2000w
    6 motor and heaters stop
    7 motor c’wise
