Beko DRVS62W T/dryer not heating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DRVS62W T/dryer not heating
  • #67348
    Redframz
    Hi Guys
    Original fault was the machine would not do anything but bleep when switched on, checked it over and found one of the rear stats had popped further checking found the front stat had popped too!
    Replaced both stats and still got the dreaded bleeping, ordered a new board from connect and fitted it today, result! the machine worked but now it’s not heating.
    Going back to it tomorrow to try and get to the bottom of it, any suggestions?
    #367156
    Seamy
    Re: Beko DRVS62W T/dryer not heating
    When you say popped, what were they reading, on the heater theres a T.O.C that can go open circuit & an N.T.C that changes reading depending on temp’, on front at top theres another N.T.C with a long lead connecting to earth. N.T.Cs are not interchangeable with T.O.Cs. Basically you can check in timed mode that its heating, in sensor/auto position heaters will shut off after a few seconds if no wet clothes are sensed by bars under door inside drum.
    There is a service mode for the dryer to test components posted on this page here….
    http://www.ukwhitegoods.co.uk/forumsphpbb3/trade-technical/known-error-codes-t40-90.html
    #367157
    Redframz
    Hi Seamy, thanks for your reply, I have been back and completed this job, bottom sensor bar was the problem.
    Regards
    David
