hi all had one of these beautys with the small motor belt burnt out , i have the new belt but i found it impossible to fit the large drum belt back in place it needs to be stretched way too much so much so that i broke the plastic motor bearing cap anyone have any info on these thx
Make 1 of these.c00098111 old Hotpoint Ariston creda belt fitting tool locate the ring And weld the ring washer further up the shaft. its still tight to slide the belt down a bit but it does work on the job and saves a sweat on 😉
Its Save the Trauma of using a very long screwdriver and a crowbar and Claret dripping on the customers floor .
