BEKO DRYER
  • #44409
    funkyboogy
    MODEL DRCS68W
    when cottons auto dry selected runs for 2 mins then cuts off
    end/anticrease led flash,s
    works perfectly on all other progs
    cheers ally
    #280896
    Seamy
    Re: BEKO DRYER
    Answer is there in your post.. its in an automatic programme.
    Either no clothes in drum,
    or clothes in drum dry enough
    or problem with sensor, worst case scenario PCB
    #280897
    smartin
    Re: BEKO DRYER
    and if you decide on pcb make sure you get the serial number 😉
    #280898
    funkyboogy
    Re: BEKO DRYER
    did have a look at sensor in drum , had bit of fluff in it nothing ott..
    it runs ok on other auto dry progs ..just not the cottons ?
    think will order pcb and sensor
    ally
    #280899
    Galway
    Re: BEKO DRYER
    is it heating fully on other programmes .these heaters always giving problems.
