beko dryer
  • #90269
    dopper
    its a dcu8230, runs for 5 mins on pre set settings then stops with tank full and filter lights on, i have checked and cleaned tank and hoses, any advice ?
    Dop
    #444231
    Re: beko dryer
    Have you checked the float and its switch?
    #444232
    dopper
    Re: beko dryer
    yes checked that all clear
    #444233
    dopper
    Re: beko dryer
    works ok on a timed setting
    #444234
    kaibart
    Re: beko dryer
    Then it’s a pcb fault
    #444235
    dopper
    Re: beko dryer
    ok cheers , it goes to end as if finished after 5 mins
    #444236
    dopper
    Re: beko dryer
    update on this one, taking a look at the board and the plug from the senor had come out a bit, so hopefully its fixed, on test now
