beko dryer Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko dryer This topic has 9 replies, 3 voices, and was last updated 7 years, 7 months ago by dopper. Viewing 10 posts - 1 through 10 (of 10 total) Author Posts September 7, 2018 at 11:44 am #94599 dopperParticipant dcu7230w put it on ex dry, it drys fine but stays on drying, does not move down the lights to end, keeps going, thinking its the pcb? September 7, 2018 at 12:53 pm #457808 electrofixModerator Re: beko dryer check both NTC check customer is not using dryer sheets like bounce as these can coat sensor check sensor is clean test prog will let you test sensor is connected and other things Dave September 10, 2018 at 7:20 am #457809 dopperParticipant Re: beko dryer cheers will do September 10, 2018 at 11:03 am #457810 dopperParticipant Re: beko dryer So did the test and wont get past spet 2 senor closed circuit, cleaned sensor and the ntc is ok so does that mean the board? Cheers September 10, 2018 at 11:04 am #457811 dopperParticipant Re: beko dryer should say step 2 September 10, 2018 at 7:26 pm #457812 electrofixModerator Re: beko dryer means board is sensing the sensor is not open circuit as it should be with no washing in check wiring to sensor and sensor its self for possible problems Dave September 11, 2018 at 7:18 am #457813 dopperParticipant Re: beko dryer cheers September 11, 2018 at 9:44 am #457814 smartinParticipant Re: beko dryer I had the same issue with my own dryer, it turned out to be the board. Martin September 11, 2018 at 11:18 am #457815 dopperParticipant Re: beko dryer cheers Martin looking that way September 14, 2018 at 9:03 am #457816 dopperParticipant Re: beko dryer update it was the board, cheers for help Author Posts Viewing 10 posts - 1 through 10 (of 10 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
