Beko dryer dcu6130 diagram
  • #95521
    deltra
    Anybody got a wiring diagram please?
    #460596
    there are 2 diagrams depending if you have a normal or led lamp
    Whats the problem with it
    can get test progs and fault codes if needed
    deltra
    Thanks Dave, originally Cust said machine was tripping,he bought a new heater fitted it and now got no heat! Went out today and pcb and heater were on kitchen bench, just need to be sure everything goes where it should !
    #460598
    had a fault like that. fitted new heater and still no heat. found a blown resistor on the pcb
    put fault up in known pcb tip but pictures failed to make upgrade on forum. from memory was a resistor feeding the ntc on the heater.
    as for wiring all the wires will normally only go in one place
    deltra
    Any diagrams Dave? Thanks
    #460600
    Can do but at the uk white goods meeting this weekend. Let me have your email and I will send you info when I get back next week
    dave
    #460601
    deltra
    deltra@hotmail.co.uk. Thank you.
    #460602
    murv
    When an NTC goes down to earth it often damages the PCB.
    If lucky the damage is limited to one or both of the SMD resistors connected to KN4 PINS 5&6
    There have been 3 revisions of PCB for this model. The heater/ NTC sensor connections are unchanged so the diagram in your inbox should help
    Murv…
    #460603
    sorted
