BEKO dryer DCU6130W = only heats for a minute
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BEKO dryer DCU6130W = only heats for a minute
  • #101617
    asp11
    I’ve not seen this fault before…. it will heat on all settings until it stops to reverse then NO heat
    I did have to reset the TOC to start with but tried it several times with the same result — heats until it goes into the first reverse then nothing???
    Any ideas please?
    #485454
    do you have to reset toc each time ?
    asp11
    electrofix wrote: do you have to reset toc each time ?
    No just the once…… then it does what I described, very weird
    #485456
    long shot check for blown board caps
