beko dryer DCU8230
  • #86491
    wilf
    no heat element ok ntc on heater reading 30 ohm seems low to me. the white leads on the board connector lead 8 meg ohm seems very high cant see where this goes but looks like behind the lower front drum. any ideas very much welcomed
    wilf
    #431894
    wilf
    Re: beko dryer DCU8230
    just looking through parts list and I see a door ntc any idea where this is and how to access it? I now suspect the high resistance leads I mentioned earlier go to moisture sensors Im going back tomorrow but any technical would help to lessen the learning curve.
    thanks wilf
    #431895
    wilf
    just in case anyone else has similar fault it was the heater ntc it seems readings outside design limits cuts out heater.had an old wma ntc in my box hooked onto the leads and away she went so ordered new heater.
    heater ntc should be 19500 ohm @25c door ntc (orange wires) should be 1200 ohm @25c
    regards wilf
