Beko Dryer DRVS62 Check Filter Light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko Dryer DRVS62 Check Filter Light
  • #91942
    subs
    Serial No.09-212733-09
    Replaced the front bearing felt and plastic runners on this machine and a week later was called to say it’s not drying the clothes. Went back and found its coming up with clean filter after running for a couple of minutes. Now it’s heating, filter, fan and vents are clear and fine. Cleaned inside sensor at bottom of drum and tested connections and readings of the ntc on heater and the one at top of drum behind facia panel. They both read around 12k ohms when tested after the dryer was a little warm.
    I’ve read it can be the board. Or could it be the cycling stat?
    Any ideas please?
    Subs
    #449784
    subs
    Re: Beko Dryer DRVS62 Check Filter Light
    Any pointers on this anyone please?
    Subs
    #449785
    captaincaveman1
    poss reversed connections on the heater ?? it is possible to do this on this model
