Beko dryer model dtgc8000w
  • #99920
    scots
    Anyone know what may be wrong here.
    Dryer not heating, checked the element ok, TOC Ok.
    The heater NTC is part of the heater assy so cant replace as NTC alone.
    I see there is another NTC after looking at parts list, wonder where it is?
    So looking at either NTC’s or board?
    Any help appreciated
    Brian
    #478474
    have emailed you the service manual
    ray.t
    I’ve had a few of these now that the wire snaps off inside the heater. I think it was the thick black wire that had come away.
    #478476
    scots
    Thanks again Dave for the info.. Suspect the board tho..
    Hi Ray heater tested ok.. I tested it from the plug on the top. thanks for help
    I did run it on a timed program so I can only assume the dryer NTC ok?
    Brian
    #478477
    ray.t
    If you have no joy with anything else I would double check the heater. The first time this happened to me I arrived at the job (no heat) and the machine worked fine. I left and told the customer to call if it happened again.
    A day or two later I had the call to go back and this time no heat. They seem to go at the point that the wire attaches to the heater.
    #478478
    scots
    Thanks Ray,
    Brian
