Beko Dryer no heat.
  • #68767
    Madmac
    DRVT61W. Went to this ‘cos the drum was jammed solid. Freed the drum but now it wont heat.
    Heater stats are both closed circ, as is the one at the top of drum at front, got live feed down at heater plug but no neutral.
    I think that only leaves the PCB itself, poss not viable repair as the cust is typical Beko buyer :rolls:
    Has anyone had success replacing one of the relays on this panel, there’s 4 of them and I aint sure which one controls the heater.
    Thanks,
    Eddie.
    #372700
    Seamy
    Re: Beko Dryer no heat.
    Eddie ,
    Basically the relays 1 & 4 supply the feed to both halfs of the heater, neutral leg goes back via stats, most likely a P.C.B will cure it, parts not expensive.
    #372701
    Madmac
    Cheers for reply seamy, I’ll see if cust will go for the repair cost of PCB replacement.
    Eddie.
