Beko dryer overheating
  • #97951
    delta01
    hi this dryer mod no DTGC8001W Has overheated the thermistor is melted its only 18 mnths old i suspect its just a heater assembly replacement but wondering if its more, any help appreciated thanks john
    #470223
    cant see anything on Beko tech about it
    can send you the service manual if you want it
    delta01
    Hi Dave that would be good thanks v much
    #470225
    dont think i have your email can you let me have it
    delta01
    Hi Dave its jhames@blueyonder,co,uk by the way are all dryer thermistors similar i would like to try just changing it thanks John
    #470227
    sorted
    delta01
    Thanks Dave i appreciate that however the thermistor i was refering to is the one on the heater assembly you normally have to buy the whole thing i am hoping to get a thermistor ( ntc ) only , thanks again John
    #470229
    if you look at the parts list they list 2 thermistors
    1457 is the front one but they also list 1741 but dont know where that one is
    if you look at the heater 2976680600 the stats are fixed by bent loops of metal so they wont supply a spare where things could break fixing it
    The manual seem to give resistance values so you should be able to check them
