Beko DSC64W condenser sensor dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DSC64W condenser sensor dryer
  • #88735
    EZappliances
    Hi All,
    Any tip on one of these Beko sensor dryers. Having just replaced the small drive belt we left the machine on test in the workshop and found whilst the timed dry programmer works fine the sensor dry programmers shut off far to early and the washing is still very damp.
    I have cleaned the metallic strips in the drum door aperture in case they were were tarnished but no change,
    I see there is a NTC in the front of the machine, could that possibly be the cause or maybe a board problem? Any assistance appreciated.
    Dave EZ Appliances
    #439194
    Re: Beko DSC64W condenser sensor dryer
    have sent you a pm
    EZappliances
    Thanks electrofix, problem solved. OC loom between moisture sensor and PCB, manual was a good help to solved this :o)
