BEKO DSC85W
  • #83923
    appliance was tripping electrics – engineer found main pcb had a burn mark on it, element etc meters out ok & no earth fault on machine.
    Engineer ordered main pcb, appliance no longer trips, but wont wont work when power goes on no lights work, there are no signs of life – until you open the door and the interior light comes on (and off when door closes)
    Is this a faulty board, or is there a programming option available?
    Alister
    #424212
    Seamy
    Re: BEKO DSC85W
    Heater is likely faulty, get the Engineer to megger it checking the NTC, they normally go low to earth & take out components on P.C.B.
    No programming necessary!
    The heaters have new better quality NTCs on them now.
    New type heater 2970101200
    New P.C.B number 2963282703
    #424213
    Re: BEKO DSC85W
    That’s great, will give those a try!
    Thank you,
    Alister
