beko dsc85w
  • #89419
    tony_partner
    hi
    my tumble dryer has stopped heating. i’ve checked continuity of the thermostat with the reset button and heater elements and both are ok.
    i’m unable to check the other thermostat untill i get into work as my own meter only measures up to 400 ohms. ( i’ve read this should be in the region of kohms)
    i’ve tested for voltage upto the thermostats and was both appear to have no supply to them( i was expecting 230v to one side even if u/s).
    does anybody know how common pcb failure is on this model or any links to a wiring diagram etc as i can’t find anything on the net.
    thanks
    #441336
    Re: beko dsc85w
    most common fault is ntc failure ( the other stat on the element. if its resistance is too high or low it wont heat
    tony_partner
    Re: beko dsc85w
    thanks, i’ll remove it and test it today. shame you have to buy the whole heater assy to get one, i bet they only cost a couple quid at most…
    #441338
    tony_partner
    Re: beko dsc85w
    just an update, it was the left hand stat that was o/c. thanks for your help
