I’m looked at one of theses dryers. The machine switches on but when you push start nothing happens. I’ve checked the door lock heater and motor and they all seem ok. I’ve only got 120 volts to the door lock. I suspect the pcb. Has anyone had anything similar
Yeah I’ve checked the child lock. I’ve checked resistance through door lock and motor. Also if you try access the test function nothing happens all the lights still flash
by the looks of the wiring diag its not a direct connected door switch it tell the pcb its closed so you might well get weird voltages on it. measure from the pcb on resistance see of it operates. assume you checked pcb for track damage
remember some models of Beko dryer have a switch on the condenser dont think this one does
from what seems to be going on it does sound like the pcb
There is 120 volts coming out of the pcb to the door lock. The rest ancestors checks ok. Would it make a difference if the lamp doesn’t work think the bulb has gone as there is power to it
