Went this machine today the Iron Dry and Clean Filter light was on. I carried out the usual checks, condenser cartridge and filter ok and the condensate pump was working as was the float switch, there was some lint in the bottom of the tank but not so much that would prevent the pump draining but I cleaned this any way. I placed a load in the machine and it ran for some 20 minutes before the lights came on, the washing to my thinking was scalding, you couldn’t hold it was that hot!!! I believe it could be a fire risk!!! Is there a sensor that controls the heat and if so where is it located? What would cause the lights to come on?
Regards
Taff
