Hi does anyone know what the NTC should read on this tumble dryer ? the one on the heater .Problem is no heat only cold air, had a new pcb under warranty then heater stops heating a few months later.
Checked element with megger and multi meter and all fine ..Stat with reset button on is fine and the NTC is reading just over 25k ohms .Heat exchanger is clear etc.
