Called out to a BEKO Condenser tumble dryer with a no heat fault. checked the heater, door NTC and the Rear TOC they all check out ok. I have also changed the PCB but still getting no heat.
I had exactly the same problem all checked ok tried PCb no better.. did start working intermittent but customer ended up buying new dryer.. so really I’m no help at all sorry
We have a Beko DT|LCE80051W in our workshop now with exactly the same problem as this . No heat but everything is testing ok .Any help would be appreciated.
can send you the manual if needed but need commercal code as there are 2 dryers with similar model no’s. Avove is taken fron commercial code 7182481740
Thanks Dave .the product code is indeed 7182481740 . If you can send us the manual (serviceappliancesdorset@gmail.com) we would really appreciate it .Cheers !
