Beko DSFN 1530 w
Viewing 5 posts - 16 through 20 (of 20 total)
  • #468964
    as you say looks ok
    as long as the wires from the stat have continuity up to the board then i can only think of 2 things left
    faulty stat or about £10
    faulty board about £41
    after that am out of ideas
    charliesdad
    Thanks for all your help Dave.
    might look at a new machine. Haven’t really got the budget for one, but I might be throwing good money after bad to keep changing parts blindly. … and don’t fancy looking up dishwashers really. My wife likes the new beko racking system,but can’t find it anywhere so it’s probably the price of gold.
    its frustrating not to be able to solve it!
    thanks again.
    #468966
    kaibart
    Did you say you checked the wires where they go through the plastic covering as that is normally where they break you can remove the white plastic thing and remove black tape and inspect as this is a very common fault on beko dishwashers when they are over 2 years old
    #468967
    charliesdad
    I will check that again. I inspected it as much as possible. I had trouble getting the front bottom cover off as it’s a torx. I think I have found a torx bit so I’ll take one last look at that loom
    #468968
    charliesdad
    Wiring all good
