Beko DSFN 6530 Keeps drinking water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DSFN 6530 Keeps drinking water
  • #86643
    Haramo
    After we move to our new house , the dishwasser does not do the task it’s created for.
    Lcd panel shows normal. If I start a program the icon with the brush lights on.
    But it does not start cleaning the dish. Only a sound I hear: like if the water continously goes out . I did some water in it, closed the washer, after some time opened it: water is gone.
    I’m
    I tried to start the test mode following the streps provided by this website , result is a symbol then the letters St .
    I searched ‘St’ in search field but no good result.
    Can someone help? Dishwasser worked great the same day it was moved to the new house but worked at the old Appartement.
    #432456
    captaincaveman1
    Re: Beko DSFN 6530 Keeps drinking water
    Sounds like its gone into anti flood which means its filled its base with water either an internal leak or overfoaming from the last wash . You need to unplug it place a towel along the left side of the dishwasher and slowly tilt it toward the towel to enable the water to run out of the base then try it again .
    #432457
    Haramo
    captaincaveman1 wrote:Sounds like its gone into anti flood which means its filled its base with water either an internal leak or overfoaming from the last wash . You need to unplug it place a towel along the left side of the dishwasher and slowly tilt it toward the towel to enable the water to run out of the base then try it again .
    thanks a lot, i’s working now,
    There came some water out, not much, then I tilled the dishwasher every side to see if more water comes out 🙂 . Then I opened the salt container, it was full of water, while this container was open I tilled the diswasher to the front, to get this water out, most is out.
    Thanks again. my wife is happy as she does not have to do the dishwas herself, and it was a lot as we had visiters 🙂
