Beko DSFN1532W (D/W)
  • #85452
    rocker
    customer tell me the machine runs through a full cycle but no water is in the tub, it sounds like it could be caused if a pressure switch with is jammed or burnt contacts, but looking up parts it doesn’t list one, can anyone please give me advice as to this fault. cheers John
    customer tells me if he holds the start switch in the wash/drain light is flashing!!
    #428649
    captaincaveman1
    Re: Beko DSFN1532W (D/W)
    They don’t have a pressure switch but instead use a water counter located under the fill chamber visable by removing the left side panel and these are a favourite for giving problems
    #428650
    rocker
    Cheers Mate. Thanks for the info. John
