Good evening everyone,
I’m struggling to cure a water leak on the above dishwasher.
The leak materialises from the bottom of the door after several minutes of a wash cycle, so I replaced the main and lower door seals only to find that the leak remained.
I then removed the outer door panel, to get a better look, and noticed water egress from both corners of the inner door section where it curves round at the bottom. (water then accumulates, prior to splashing out randomly anywhere along this section) the dispenser area, and door are bone dry.
Now wondering if the door is warped, or should I be suspecting something else such as a porous cabinet/seam?
jonty
