Beko dtgc7000s melted plug
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko dtgc7000s melted plug
  • #101376
    1rtomlinson
    The plug on my tumble dryer has stopped the dryer working. Looks like the plug has melted inside.
    https://photos.app.goo.gl/U9DbhUYqKpaeKB23A
    The dryer is around 5 years old and I’ve not had an issue with it up to now. Do you think it’s worth repairing or should I look at replacing the dryer with a heat pump model?
    Thanks in advance
    #484527
    put a new plug on it and possibly the socket and it will be fine
    tubafan
    Agree with [USER=”4209″]electrofix[/USER] – just change the plug. The pins on the old one look ok so I think it’s just the fuseholder that has burnt out. If the socket has no evidence of heat damage then it’s likely fine.
    #484529
    1rtomlinson
    Thanks. DIY not my forte so was going to get a replacement for the whole power cable are they easy enough to change?
    ​​​https://www.espares.co.uk/product/es1795435/power-cable
    #484530
    have you got a local electrical shop
    if yes take the lead off, take it down to them and ask them to fit a new plug.
    yes that lead will fit but at almost £30 against a £3 plugtop. even if they charge you £20 to fit the plug your still ahead
